2-Explorer
Flat Belts
Imagine I have a length of flat belt or tape, laying on a table, with one
end hanging over the edge of the table. On the other end of the tape stands
something: A mug of coffee, say.
In Pro/E, I want to grab the droopy end of the tape and pull it down towards
the floor and see the coffee move closer to the edge of the table.
Very simple in real life, but I can't think how to do it in Pro/E.
Any ideas?
John
This email, including any attachment, is a confidential communication
intended solely for the use of the individual or entity to whom it is
addressed. It contains information which is private and may be proprietary
or covered by legal professional privilege. If you have received this email
in error, please notify the sender upon receipt, and immediately delete it
from your system.
Anything contained in this email that is not connected with the businesses
of this company is neither endorsed by nor is the liability of this company.
Whilst we have taken reasonable precautions to ensure that any attachment to
this email has been swept for viruses, we cannot accept liability for any
damage sustained as a result of software viruses, and would advise that you
carry out your own virus checks before opening any attachment.
    John,
    See the attached assembly file -- sorry I didn't add the coffee. The
    models are in WF3 but I didn't do anything that couldn't be done in WF2.
    If you can live with a segmented belt, this is a pretty elegant
    solution. Just select the "drag hand" icon, select somewhere on the
    belt and then move the cursor around. The Edit / Repeat command came in
    very, very handy here.
    If you need a smooth belt, you're going to be limited to a regenerated
    solution. Open up "perimeter_example.prt", modify the surface feature
    and change the 14 dimension to something smaller, say 4. Regenerate and
    you'll see the "belt" move to maintain its length of 30. This uses the
    sketcher's "edit/convert to/perimeter" capability -- very powerful and
    once you understand it, quite handy.
    Hope that helps.
    Kevin Schoonover
    PTC Channel Technical Manager
    Western North America
