May 22, 2012 11:55 AM UTC
Flatten Form
Is there a re-form/bend back after flatten form?
    wfalco16-PearlAuthor
    May 24, 2012 2:22 AM UTC
    No takers?
    May 24, 2012 5:11 AM UTC
    Let me clarify:
    Normally you un flatten and create a feature, then bend back.
    I want to do the same with a form feature.
    I can flatten a form....like unbending - in a sense.
    I would like to create a feature on the flat.....then form back (like
    bend back) ....but I don't see it.
    Flatten form is under shapes as bend back is under bend commands.
    May 24, 2012 11:23 AM UTC
    Is it something that you can do in sheet metal? Use the flatten tool then suppress the "flatten"?
