2-Explorer
flatten quilt
Hello, Happy Friday...
I am trying to flatten a quilt. I have used the "Flatten Quilt" tool
before. It sure is a great tool when it works in "auto" mode.
I think my problem today comes from the fact that the quilt is an extrude
with a variable draft:
Any hints on how to get this to unwrap?
    bbrejcha
    To flatten the quilt ... the most common mistake is you did not supply the
    surface a datum point. The PNT needs to be on one corner of the surface.
    call me if you have troubles and I'll walk you thru it over the phone.
    Monday of course.
    Bart Brejcha
    *DESIGN-ENGINE|**EDUCATION*
    Bart Brejecha designengine.com
    Depending on the the surface and its edges... the point may or may not
    need to be on the corner, it may just be along an edge somewhere. -Jon
