Followup to problem with opskip
Found where the problem is, just not sure how to fix it.
I have code in my FIL as follows;
$$ this routine will start the ROUTER PROCESS ENABLE G58
CIMFIL/ON,PIERCE
T4TH=POSTF(7,4)
CASE/T4TH
WHEN/ICODEF(ON) $$ Always want to turn pierce on when told to
INSERT/'M58$'
WHEN/ICODEF(OFF)
RSLT=POSTF(14) $$ Read the next command line to see if it turns pierce back on
RSLT=POSTF(20) $$ Save this read cL record
T5TH=POSTF(7,4)
IF(T5TH.EQ.ICODEF(ON)) THEN
$$INSERT/'DETECTED REPEAT$'
ELSE
$$INSERT/'NO REPEAT DETECTED$'
INSERT/'M59$'
RSLT=POSTF(21)
RSLT=POSTF(13)
ENDIF
ENDCAS
CIMFIL/OF
If I delete this code the opskip works perfect. What in the above code is causing the opskip to fail?
    Is there a line missing before the ELSE statement when performing the "IF" routine inside the "CASE" statement? Nothing is happening here that I see.
    Jay Crook
    Norse Dairy Systems
    jcrook@norse.com
