Font Types
How do you make Pro/E Wildfire 2.0 M180, Read:
Adobe font type: Delta Jaeger Bold.pfm
while in: Note Properties, Text Style, Charater,Font.
DKL
    mrproe1-VisitorAuthor
    Hi David,
    This is in reference to call number C5253574. The issue is "How to use ‘.pfm’ fonts with Pro/ENGINEER Wildfire 2.0?"
    Postscript type1 fonts (.pfb and .pfm) fonts are not supported in Pro/ENGINEER. Only true type fonts are supported in Wildfire 2.0. Both ‘True type’ and ‘Open type' fonts are supported in Wildfire 3.0.
    Seshu Kumar
    Technical Support Engineer
    Technical Support
    PTC
    Contact Technical Support
    In some cases WF2.0 does not completely support True Type either.
    At least, recent experience with a filled font showed some translation
    problem that left the font unreadable on printouts and PDF files, even
    though it looked ok on the screen.
    The work-around was to use Adobe Illustrator to convert the text into filled
    outlines and import them as DXF format files. Rather an expensive font
    squashing utility.
    The same fonts render correctly from Microsoft Word, et al.
    It appeared to be a winding-rule evaluation problem.
    Dave S. (Not the David referred to below.)
