Fori filettati
Ho installato la versione Personal Edition del programma; avrei la necessità di creare dei fori filettati ad esempio M6x10 M7x15 ecc. con tanto di preforo standard. Non riesco a trovare la libreria standard relativa ai fori lisci o filettati. Dove si trova? Dove devo eventualmente scaricarla? Un programma di modellazione 3d così legata al disegno tecnico non può essere sprovvista di tale accessorio!!! Grazie per l'aiuto
    Hope you will understand my English answer. There are library modules for the commercial version of Modeling PE which should have all the required standard parts.
    Thank you for the answer clausb, i checked the link but i didn't find the library modules you talked about. If you know more exactly where to download them, please inform me. I need to perform standard Holes on surfaces (Threade or smooth holes) Thank you again
    The link in my previous message referred to my blog and web site, so no surprise you didn't find product descriptions there 8-) http://www.ptc.com/products/cocreate/part-library describes our Part Library module, which might be relevant here. The functionality in the Machining module may also apply. I know very little about these modules (so please somebody correct me if I'm wrong), but as far as I know, they are available for the commercial version only. Claus
