FRIDAY RANT
When is PTC going to add a Through All / Both Sides button to the extrude
dashboard? I use that combination all the time for cut features
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
    2-Explorer
    Or even better, to the RMB menu?
    Possibly when they add a SLOT feature
    Anthony R. Benitez
    Senior Mechanical Designer
    Drafting Supervisor
    Applied Research Laboratories
    The University of Texas at Austin
    "What you need to do is send in what we call an enhancement request. We
    evaluate the number of customers that.....CLICK.....bzzzzzzzzzzzzzzz"
    Bob Frindt
    Sr. Designer
    Parker Hannifin Corporation
    Parker Aerospace
    Gas Turbine Fuel Systems Division
    9200 Tyler Boulevard
    Mentor, OH 44060 USA
    direct (440) 954-8159
    cell: (216) 990-8711
    fax: (440) 954-8111
    www.parker.com
    "Lyle Beidler" <->
    05/22/2009 08:05 AM
    Please respond to
    "Lyle Beidler" <->
    To
    cc
    Subject
    [proecad] - FRIDAY RANT
    Lyle Beidler
    MGS Inc
    Denver PA 17517
    717-336-7528
    Fax 717-336-0514
    MAYBE JUUUUUST MAYBE THEY NEED TO HIRE A DFAFTSMAN/DESIGNER/ENGINEER ON
    STAFF TO GUIDE THE GUIDE THERE
    DIGIGEEK HANDS IN THE PROPER DIRECTION FOR THE REAL WORLD
    "Wayman John"
    <john.wayman@uk.t <br="/> halesgroup.com> To
    22.05.2009 15:50 cc
    Subject
    Please respond to [proecad] - RE: FRIDAY RANT
    "Wayman John"
    Chris3
    Am I missing something?
    Chris
    Andy had a good point - I created a mapkey to do it.
    Hey, sometimes good stuff comes from a rant..
    Lyle Beidler
    MGS Inc
    Denver PA 17517
    717-336-7528
    Fax 717-336-0514
    <">mailto:-> -
    These Posts are FUN for a stress reliever.
    Seriously, I would be happy with a Product that simply didn't crash !! or
    was predictable and consistent.
    Just this last week, I've had 3 Pro/Dumps losing 4-6 hours of work. Yea I
    know its easier to do the work the second time. but having Pro simply leave
    you at your desktop is Very frustrating ( to say the least ).
    Todd Malenke - Design Engineering
    Machining & Welding by Olsen, Inc.
    250 Olsen Blvd, Cokato, MN 55321
    952-516-7655 - Direct
    320-286-2187 - Phone
    320-286-2962 - Fax
    Although this would be a nice capability, it's not that hard to use Both-Sides, and enter a depth that is well beyond the part extents. If neccessary, use a relation to ensure that the depth is adequate.
    However, there is a more practical issue. In the past, I've done timing tests, and found that the Thru-All option (when available) is significantly slower than a fixed depth. I assume that Pro/E simply takes too much time to determine the depth needed to go through the part. Therefore, I no longer use Thru-All anymore.
    In Reply to Lyle Beidler:
    Holy doubleicty Batman!
    Seriously though as if one thru all was not bad enough. If you want
    fast models, don't let Pro/E do the thinking for you, but rather build
    in the design intent yourself. Thru all means Pro/E has to pause
    creating the feature, calculate the bounding box for the finished part
    then go back and finish the feature. If you were building a model and
    using just what's necessary to conserve energy and time, thus making it
    most efficient. You would not run out to infinity, but rather just to
    where it's necessary, like up to a surface, or to what's needed, say a
    distance.
    Tim P. Cooper
    Lockheed Martin Mission Services
    Orion Crew Exploration Vehicle
    Radiation Analysis
    Physical Address: Correspondence:
    2625 Bay Area Blvd LM1, Mail Code: A7A
    Houston, TX 77058 P.O. Box 58487
    (281) 283-4372 Houston, TX 77258-8784
    (281) 283-4199 (F)
