Feb 9, 2016 7:43 AM UTC
Having problem
when i installed creo Parametic it is saying that Crea Parametric is shutting down because it could not run the quality Agen, which is required in this edition if you can call Technical support about this problem, report error 0x06000003
Feb 9, 2016 3:45 PM UTC
Hi
There is a similar thread ==> Creo won't run!!!
Maybe you can check and test solutions
