Nov 24, 2010 9:48 AM UTC
helix
how to create helix in proe wildfire 4.0
    Dec 7, 2010 7:58 PM UTC
    Rajesh,
    What are you trying to do exactly? Use Helical Sweep to create threads, springs, helical surfaces; use From Equation Curves to create a helical curve.
    David
    Dec 10, 2010 12:49 PM UTC
    could u tell me formula for making 3Dhelical sketch/curve!
    i DONT KNOW HOW TO DO THAT!
    Dec 13, 2010 8:55 PM UTC
    I believe you can find an example in the Help files, but here you go:
    Create a Curve, By Equation, select a Coordinate System with Z on the axis of the helix, and choose the Cylindrical option.
    Now enter the following equations:
    r=2
    theta=t*360*8
    z=t*5
    These are examples of true parametric equations. In this case t is the governing parameter, and by definition it is the independent variable which goes from 0 to 1 to generate the dependent values. Thus, the 8 gives you 8 full turns, and the 5 gives you a z-height of 5, radius of 2. This can also be done with the Cartesian option using sin and cos, but Cylindrical is the easiest.
