Mar 17, 2011 2:01 AM UTC
Help Center not working, and neither is my eLearning Library
It sure would help if my resource center was working. When I click on help center, the mouse cursor changes to the busy icon and the program just hangs. In the tray, I get a nice circle with an X icon relling me that Help Center is running, but that's about it.
If I double click the icon, it eventually brings up a browser with the default help page. Context Sensitive Help is therefore also useless.
I paid for the eLearning Library 1 year subscription, and cannot log into that either.
How do I get this working? What did I just pay $200 for? Tech support is unresponsive.
Windows 7 Professional x64 SP1
8GB RAM
    Mar 17, 2011 8:49 AM UTC
    Sebastian,
    please, if you describe your problem provide us with detailed description ... E.g. I don't understand what you mean with "resource center" and "When I click on help center, ...".
    Note: Sometimes PTC websites do not work correctly in specific browser. User can try IE7, IE8 and Firefox 3.6. ...
    Martin
    Mar 17, 2011 12:35 PM UTC
    Help Center, as in the Help menu -> Help Center selection fron Pro/E. PTC's web site apparently doesn't work in the Pro/E browser which is used for the help files then.
    Mar 17, 2011 1:57 PM UTC
    Sebastian,
    by default, Help > Help Center from Pro/E launches locally installed PTC/Help (in ProE Wildfire 5.0). If you install ProE Wildfire 5.0, you have to select PTC/Help item to install it properly. PTC/Help is installed in PROE\html\proe_help directory.
    Martin
    Mar 20, 2011 6:14 PM UTC
    Sebastian,
    I tested installation of PTC/HELP WF5 in Windows 7 Professional 64-bit (I don't have SP1 installed).
    I used commercial installation package Creo Elements/Pro M080.
    On my computer PTC/HELP WF5 works fine.
    I am sorry I don't have any other idea concerning your problem. So I give up...
    Martin
