Help in Creating Fillets
It's real easy to create a curved blend of two adjacent flat surfaces to give a nice rounded edge. Is there an equallly simple way of creating a fillet between two adjacent flat surfaces ?
    Yes. You create internal blends the same way you create external blends.....Use the blend commands. The feedback will show you what it looks like.
    Thank you Mike. Again you guys either come uo with the answers or you set the mind thinking so as to figure it out. I had already tried the blend on two adjacent parts without success. I kept getting an error message ""Edge is tangential - cannot be blended"". However, when you replied saying it can be done I thought about it and figured out my problem. I simply had to ""Unite"" the two parts and then the blend worked like a charm. Thanks a million. By the way Mike, did you get my e-mail regarding my problem uniting parts ? Cheers, John.
    Hello John, You started down the path of creating individual features as individual parts and then trying to unite them. This is not a good process, (although it can be handy at times). When you need to add a feature to your part, make sure your current part is the active part, then simply put a new workplane on the face where the new feature is to go. Create the outline and use machining commands to add the additional feature. I looked at your assemblies, and while each of your parts appars ok to the eye the faces do not exactly touch, so when you start trying to unite the parts, you wind up with all sorts of additional faces and short edges. There is a command in Modeling PE called ""check part"" You will find it in the Modify 3D section. It will tell you a lot about your models. Turn maximal check on, turn verbose on, and turn labels on. I spent an hour or so this morning playing with some of your parts and assemblies trying to turn it into one part. I didn't sent it back to you because I'm not sure if some of the fixes I did were part of your design intent.
