Jun 8, 2015 7:02 AM UTC
Help in creating parting line
Can anyone help me in creating parting line for the attached component.
I could not able to do so.
Thanks in Advance
Amit
    Jun 11, 2015 7:45 PM UTC
    It seems like the worst spots are the transition from the end diameters to the main body. You can try to tweak those a bit.
    Jun 20, 2015 7:51 PM UTC
    Well it aint flat if that's what you want. I rotated the part so the center section is vertical and you can put the P/L where ever you want in that area. The rest really aint bad, do the silhouette curve and then the areas where it dont match 100% just do a projection in that area to smooth it out. Then copy each side as 1 curve and away ya go with a split.
    Have fun.
    amitshah1-VisitorAuthor
    Jun 24, 2015 7:34 AM UTC
    Hi Gary,
    I tried hard to create a silhouette curve but withouot success. Is there any way to easily create silhouette curve.
    Jun 26, 2015 8:12 PM UTC
    Which way are you trying to orientate it? And which part are you having trouble with?
    Jun 27, 2015 12:00 PM UTC
