Aug 11, 2011 2:18 AM UTC
Help me
HIii
i am new here. i am using this soft just in a month ago. i need some help .
1)how i save a model in package and stl format
2)here any option for ,see my model in automatic rotation
Karthi
    Aug 11, 2011 3:03 AM UTC
    Hello
    1) "File" --> "Save-as" --> "Type" --> "Shrinkrap" or "STL" (options on shrinkrap for package include Master Merge --> STL
    2) By default pro/e does not save animation of parts to rotate in a web page. To animate rotation you have a couple of options.
    a) If you have design animation you can use "Application" "Animation" and rotate part to create a movie.
    b) Option 2 is create your own pictures with "File" :"Save-as" :"*.jpg" - Multimple ones required to make your own animation.
    c) If you own product view it's easy to create animation.
    A couple of examples can be found on PTC help page.
    Regards
    Paul Lalinde
    P.S. Welcome to world of PTC.
    Aug 11, 2011 4:07 AM UTC
    i got an error message while saving my model in stl format.
    that is(you must specify atleast one part or assembly Error414)
    what i do??
    Aug 11, 2011 5:54 AM UTC
    Which version of Pro/ENGINEER are you using?
    P.S. Can you attach a 3D-model, which is saved in the format of STL?
    Also, a forum on Creo (including Creo / Elements Pro) is available here: http://communities.ptc.com/community/creo
    Aug 11, 2011 1:44 PM UTC
    Hello karthi keyan,
    I moved your discussion into the Creo community. This wil be a better audience for you to receive a response to your question
    Thank you,
    Dan
    Aug 13, 2011 4:53 AM UTC
    hiii
    plz help me...how i save my model in stl format???
    Aug 13, 2011 5:37 AM UTC
    Ya ..No prob guys.. i find out how to save model in stl format ...it's very easy...
