Jul 15, 2014 8:43 AM UTC
Help with .STP Files
Good Morning,
Can anyone advise me if there is a way to create a section view within a .stp file import.
Paul
    Jul 15, 2014 11:57 AM UTC
    Once a STP file is imported, it becomes a part or assembly file. Anything you can do to a part or assembly, you can do to it.
    That said, if the import only produces surface geometry and no solids, then you will not be able to section it just like you cannot section a part or assembly file that contains only surface features.
