Aug 24, 2011 2:07 PM UTC
HOLE COLOR DEPENDING ON PITCH
Hi all,
Any Idea on how to make the hole a different color depending on the thread size automatically?
This will make checking that we use the right fastner when using fine thread a lot easier.
Nicolas
    Aug 29, 2011 9:56 AM UTC
    Hi Nicolas,
    the only way that comes to mind right now is to use UDFs instead of the original hole feature.
    You could create UDFs for each thead needed and transport the coloring via the UDF.
