Sep 19, 2012 2:15 PM UTC
hole files incomplete
When did PTC stop filling in hole information in the .hol files?
Starting at 9/16 they do not have any information for clearance holes.
Why?
    Sep 19, 2012 6:10 PM UTC
    My WF2 hole files (2005) are also blank for clearance hole information, so it has been a while.
    Easy enough to modify and add what data you need.
    I have often modified the tables for the drill size that the shop wants rather than use the PTC supplied data.
    Thank you,
    Ben H. Loosli
    USEC, INC.
    Sep 19, 2012 6:27 PM UTC
    When I did a corporate setup, I also edited the hole tables... I eliminated all but the standard coarse and fine thread versions of both the standard and iso styles... That way I didn't have someone mistakenly using a hard to obtain thread...
    just a thought...
    Chris3
    Sep 20, 2012 4:38 PM UTC
    It's because the information comes from the Machine Handbook (table 4 "Tap Drills and Clearance Drills for Machine Screws with American National Thread Form")
    The table in the handbook stops at ½ inch.
    Christopher Rees - Mechanical Engineer - ISR Systems
    UTC AEROSPACE SYSTEMS
    100 Wooster Heights Rd, Danbury, CT 06770 U.S.A.
