Feb 29, 2016 12:52 PM UTC
Hole Table
Hello everyone,
In hole table how can I get or hole table gives the holes in ascending order (in terms of diameter i.e, 3,3,4,5,5,6....etc.) (Creo 3.0)
    adeshmukhAnswer
    Mar 2, 2016 9:39 AM UTC
    Uncheck the “Use default” box and select Diameter as Sort Column.
    18-Opal
    Feb 29, 2016 8:32 PM UTC
    Hi Akshay,
    Could you please clarify?  I'm not sure what your question is.
    Amit
    adeshmukh1-VisitorAuthor
    Mar 1, 2016 5:41 AM UTC
    Hi Amit,
    hole table shows all the holes in your parts with diameter
    If your parts contain min. dia. of 3mm and then say 6mm, 8mm, 10mm etc
    so i want in hole table the diameter of holes should show in ascending order for ex. first it show 3mm then 6mm, 8mm etc.
    Hole table shows you as per you apply holes if you apply 10mm hole first then it shows you at first no. 10mm hole in hole table.
    18-Opal
    Mar 1, 2016 8:25 PM UTC
    Hi Akshay,
    Unfortunately, it is not possible to sort the order of the hole table.
    Amit
    adeshmukh1-VisitorAuthorAnswer
    18-Opal
    Mar 2, 2016 8:14 PM UTC
    Hi Akshay,
    Thanks for the update.  I had found an article that stated it was not possible.  I will need to update it to show the correct behavior.
    CS158078 - Is it possible to sort order of Hole Table in Creo Parametric 2.0
    Amit
    Mar 2, 2016 8:34 PM UTC
    There is a reason we don't always believe PTC's support technicians
    Thanks for updating your records.
