hole table display of UNC/UNF holes
The description of both tapped and clearance holes shows up the same
when using the hole table ie the default note is "10-32 UNF" How do
you change the display to the full note
ie
10-32 UNF-2b thru
or
10-32 UNF Clearance
Drill (.201)........
WF5 F000
    Bill,
    You can get some great info on Hole Feature Annotation customizing at this Webcast EAC Product Development Solutions hosted on August 14th of this year: http://www.eacpds.com/webcasts
    Enjoy!
    Doug Hippe
