Hole table problem
I have a plate with many holes in, some are thro one side and some holes are countersunk on the other side. My problem is that when I create a hole table, the holes that are countersunk on the other side do not show up in the table! Does anyone know how to get all the holes to show up (holes from both sides) in the table.
Thanks in advance.
Jeff
    Gurus?
    It seems to me that there should be 2 different hole tables in this case.
    When you place references for the tooling it would require that you turn the
    piece part over and do the opposite side separately.
    I think that sometimes we need to view our designs in terms of
    manufacturing. Then "maybe" it will make sense.
    Michael P. Locascio
