Hole Tables
Good Morning All,
Is it possible to paginate a hole table? It does not seem to work like a report table.
    CharlesAnswer
    Keith,
    When creating the hole table, click the "Maximum" number of rows and insert the number of the row that you want to end the paginate. Then click on the screen where the rest of the table should be.
    Did you get an answer to this?
    It is possible, which version of Pro/E or Creo are you on?
    Charles1-VisitorAuthor
    I am using Creo 2.0 and yes, I did find the answer.
    Good stuff.
    I don't suppose you know if it is possible to get a comma as a decimal marker in the hole tables do you???
    I thought all you had to do was change the drawing properties, but that does not seem to have any effect on the table
    Charles, Where did you find the answer to pagination of hole tables and what is it?
    Charles1-VisitorAuthorAnswer
    Keith,
    Charles,
    Thank you for the quick reply. I was able to get the pagination I needed.
    -Keith
