Holes with drill point
Is there a way in WF2 to put in a hole that has a drill point? The desired
result I am after is like using a tapped hole, there is an angle number on
the bottom I can change. However I want to be able to specify the diameter
of the hole by in putting my own value not by letting the tap thread
determine my hole size.
Ron
