Hollow Sphere ?
As a follow up to my last post, I guess what I want to do is to create a hollow sphere, cut it in half and then cut it in half again.
    The attached 3D model file should explain my problem. How do I fill in between the 3 faces to form a quarter of a hollow sphere ?
    Create a workplane and a profile like the one shown. Use the Turn command. Use one of the construction lines to define the axis of rotation, and enter in 90 degrees (or -90 degrees) as the angle.
    Thank you, Mike. John.
