11-Garnet
Aug 28, 2014 9:19 AM UTC
How can I set color of sketcher in creo 2.0
I want to set black background color in sketcher,but I set gray background color in 3D
I can't split their color when I set background color from File-->option-->system color -->background color,hey change together
How can I split their color ?
3D background color is gray (like picture A)
A.jpgA
2D Sketch background color is black (like picture B)
B.jpgB
How can I make them show different color?
Thank you
    DRFaustAnswer
    Aug 31, 2014 2:45 AM UTC
    I hope this is correct and works for you. For my installation of Creo Parametric 2.0 I took a copy of my syscol.scl file from my version of WildFire 5.0 that I was running and put in the location Creo 2.0 is pulling it's syscol.scl file from and all my set colors worked perfectly. I also attached a copy of my syscol.scl file if you want to try it. Notice my color scheme in the config is set to custom.
    Good luck...
    Aug 28, 2014 7:02 PM UTC
    I don't have a Creo in front of me (right now), but it should work like in Wildfire.
    Have you tried the config.pro option
    sketcher_blended_background no
    (as I remember correctly
    you have to set the gradients color for part and assembly mode
    and in addtion you can set a non gradient color (in your case black)
    but there is a downside - you can't set the sketcher and the drawing mode backgound independently)
    There are several youtube videos out there, regarding the background color, e.g.
    https://www.youtube.com/watch?v=gqERbvgjv84
    hth
    yhuang-211-GarnetAuthor
    11-Garnet
    Aug 31, 2014 1:14 PM UTC
    Thank you for your replying. Maybe I need to set BLENDED_BACKGROUND yes in syscol.scl
    DRFaust12-AmethystAnswer
    Good luck...
    11-Garnet
    Aug 31, 2014 1:13 PM UTC
    Thank you for your replying I will study your syscol.scl. Maybe keyman is BLENDED_BACKGROUND yes .
    Aug 31, 2014 7:36 PM UTC
    I also remember setting my config file to the following where the prementioned syscol.scl file was located.:
    As a fnal note, when I installed my Creo Parametric 3.0 I referenced the same syscol.scl file and it loaded the same system colors as 2.0.
    Have a great weekend...
