Sep 27, 2016 11:33 AM UTC
How do I import a metric model and have it covert to inches automatically
    Sep 27, 2016 12:41 PM UTC
    what does mean "import a metric model" ?
    MH
    ldesign1-VisitorAuthor
    Sep 27, 2016 1:00 PM UTC
    I was hoping there was a config that would do it as I imported the model.
    Sep 27, 2016 4:58 PM UTC
    In our setup, we have saved a recipe called 3rd_party_model_import.dip using the Import Profile editor tool (look in Tools/Utilities ribbon).
    This recipe specifies (among many other things) that a template model should be used when importing parts and assemblies.
    Also, we have created template models and assemblies and configured them with metric units and the typical parameters, key layers and datums we use in our regular models.
    Then in the config.pro, we have the line:
    intf_in_profile_default c:\pro_config_dir\3rd_party_model_import.dip
    We typically import in STEP files; with this default recipe in place, they always come in with metric units (the size conversion happens automatically).
    Sep 28, 2016 10:20 PM UTC
    We use import profiles here. Also we have mapkeys to automate further.
    We set config option   intf_in_use_template_models  to  yes, although not necessary when using profiles or mapkeys.
