How do I make a rabbit shape around an edge?
I am a new user and having problems creating a rabbit around an object. I have included a jpg. It shows a box around the edge i want the shape cut out of. Beside that an "L" shape to represent 0.125 x 0.125. I would like to know how to cut the "L" shape out all around the top edge of the object. In the wood shop I'd call this a rabbit. One method I came up with was to offset all the edges in 0.125 as a sketch then extrude the sketch up 0.125. This didn't work because I couldn't get holes to cut through the two individual surfaces. I think there may be a way to join the two pieces then cut the holes but I haven't figured it out. Thanks in advance for any help.
    Jim, Sounds like you need to do a Swept Cut using the edge of the part as the Trajectory. Can't tell for sure from your picture. David
    If this is just one extruded feature you could use the same sketch to extrude a cut .125 deep with a wall thickness of .125
    Try out the Lip feature. Insert > Advanced > Lip Erik
