Oct 28, 2015 2:08 PM UTC
How do you make an overlay in Creo?
How do you make an overlay in Creo? I'm converting from one system to another and the Creo asm has some compo
nents that are out of place, I thought that if I can make an overlay I can find out where those components go.
    StephenW
    Oct 28, 2015 2:12 PM UTC
    I'm not sure I understand your question. Do you want to compare an old revision?
    jjimenez1-VisitorAuthor
    Oct 28, 2015 2:24 PM UTC
    I'm working on an asm that was converted from a catia model. However in the converting process some of the components in the Creo model are out of place. Is there a way to make an overlay so I can see where those componets in the Catia model are, so that I can move them in the Creo model to the correct position?
    StephenW
    Oct 28, 2015 2:44 PM UTC
    Makes sense now.
    If you still have access to the catia models, you could make a step file (or iges or ???) and import that. Not sure how that would be better than just looking at the catia model to find the parts.
