Sep 13, 2013 1:19 PM UTC
how to add row above?
After I insert a table, I want to add a row above, but I only can add a row below. How to switch from "add row below" to "add row above".
I didn't find option.
    jzhang-3Answer
    Sep 17, 2013 3:23 PM UTC
    Ok, I figure out. To select entire table or rows, and then select properties (table properties vs. note properties), a window pop up, there are 4 options of direction, to select last one - bottom up. you can add row above.
    Dale_Rosema
    Sep 13, 2013 2:44 PM UTC
    If you click on the top portion of the top row when you are adding a row, it will add one above. My particular table shifted down but that's because the table was a top-down propagated table. For bottom up tables, if you click on the top portion of the row, it adds another row above where you clicked (even in the middle of tables).
    jzhang-31-VisitorAuthor
    Sep 13, 2013 4:01 PM UTC
    It is a bottom-up table in ProE Wildfire 5 and always add row above. I just check this table again in ProE Wildfire 5, it still add row above as reqired, but it don't work in the same way in Creo Parametric 2.0. We will use most of prints from Wildfire 5 and update in Creo 2.0 by adding row for new revisions, it will be disaster if I can find a way to "add row above" in old tables!!!
    jzhang-31-VisitorAuthorAnswer
