Mar 27, 2015 11:59 AM UTC
How to change default depth value IN Extrude
How to change default depth value IN Extrude...
Apr 9, 2015 11:35 PM UTC
Hi Dinesh,
Currently, there is no way to change the default extrude value. The following Product Idea exists and is available for voting.
Depth of Extrude
Patriot_1776
Apr 13, 2015 1:48 PM UTC
Not directly, but what I did was in my start models I put a sketch of a circle, the diameter about the average size of the parts we typically make. This keeps the system from making the part ridiculously big. You can always delete it afterwards if desired, but I leave them in because it's geometry that can be used to point a repeat region BOM balloon leader to if needed.
