Dec 18, 2012 11:39 AM UTC
how to configure tree.cfg
Hi everyone,
I want to configure Model tree to don't need to se the parameter properties. The ideia is simple, if i had the Type set to String and Values for the colums, i need only select for my parts.
Anyone have some idea, how to do this?
Thanks!
    Dec 18, 2012 4:23 PM UTC
    I'm still using Wildfire 5.0, M060, so this may not apply to you.
    On the top of the model tree there is a button that looks like a hammer and wrench standing vertical. Select this and choose Save Settings File. This will allow you to save your model tree in it's current configuration. You'll want to save in a place where it will be safe. I use my startup folder to save files like this. Now add a line to you config.pro "mdl_tree_cfg_file C:\Program Files\proeWildfire 5.0\text\tree.cfg". This will start ProE using this tree config.
    Don't forget, get your model tree to look just the way you want it to before you save the tree config file.
    Tim
    Dec 19, 2012 10:29 AM UTC
    I know that Tim, but my problem is other.
    The Problem is: How to make a drop down menu at model tree? When open the model tree, we expect have all opions pre configured. It's look like this
    Material : Stell
    Iron
    Wood
    I will select one, and don't need to write every time.
    Dec 19, 2012 2:38 PM UTC
    You can create parameters with restricted values, you have to look in the help files.
    Does it work in model tree ? I dont know.
    Reinhard
