Dec 19, 2016 6:08 PM UTC
How to create material library file in CREO?
In our material library we have very few materials only.
Now i have to add more material files in creo material library.
Please suggest for creating material library files.
By
uday
    BenLoosliAnswer
    Dec 19, 2016 7:47 PM UTC
    They are simple text files.
    Rename an existing one and edit it for your own names and parameters.
    There is also an icon to create a new one from within Creo, but it is very generic.
    BenLoosli23-Emerald IIIAnswer
    Dec 19, 2016 10:30 PM UTC
    Hello
    You have that which is compatible with Creo.
    Kind regards.
    Denis
    http://www.totalmateria.com/page.aspx?ID=Home&LN=FR
    Dec 19, 2016 10:53 PM UTC
    Create a new material file with dummy data and then edit it in a simple text editor. See what each set of lines says and does and then add the properties for your materials.
    Here is the start part default file we use.
    ND_RelParSet_K01 = {
    Name = START_MATERIAL
    PARAMETERS =
      Name = PTC_MATERIAL_DESCRIPTION
      Type = String
      Default = 'PDM Number, Description 1
    Description 2
    Description 3'
      Access = Full
      Name = TEMPERATURE
      Type = Real
      Default = 0.000000e+00 F
      Access = Full
      Name = PTC_INITIAL_BEND_Y_FACTOR
      Type = Real
      Default = 5.000000e-01
      Access = Full
      Name = PTC_BEND_TABLE
      Type = String
      Default = ''
      Access = Full
      Name = PTC_MATERIAL_TYPE
      Type = Integer
      Default = 9
      Access = Locked
      Name = PTC_FAILURE_CRITERION_TYPE
      Type = String
      Default = 'NONE'
      Access = Locked
      Name = PTC_FATIGUE_TYPE
      Type = String
      Default = 'NONE'
      Access = Locked
      Name = PTC_MASS_DENSITY
      Type = Real
      Default = 9.900000e+01 lbm/in^3
      Access = Full
      Name = PDM_NUMBER
      Type = String
      Default = 'PROE_SETUP'
      Access = Full
      Name = PDM_NAME
      Type = String
      Default = 'Start Material Name'
      Access = Full
      Name = DESCRIPTION1_U
      Type = String
      Default = 'PDM Number, Description 1'
      Access = Full
      Name = DESCRIPTION2_U
      Type = String
      Default = 'Start Material Description 2'
      Access = Full
      Name = DESCRIPTION3_U
      Type = String
      Access = Full
      Name = DATA_SOURCE
      Type = String
      Default = 'Source for material properties'
      Access = Full
      Name = VERSION
      Type = String
      Default = 'Version of material file'
      Access = Full
      Name = CATEGORY
      Type = String
      Default = 'Material category type'
      Access = Full
      Name = COMMENT1
      Type = String
      Default = 'Material used for setup of start parts.'
      Access = Full
      Name = COMMENT2
      Type = String
      Default = 'Any other comments about material.'
      Access = Full
    us_0110-MarbleAuthor
    Dec 23, 2016 5:25 AM UTC
    Hi
    Thanks ben. It is useful for us.
