7-Bedrock
Mar 11, 2015 3:06 AM UTC
How to create straight NPT’s in Pro/E Creo
    Mar 11, 2015 6:56 AM UTC
    You might have to create your own hole table for NPS and NPSF.
    The host of straight pipe threads are mind boggling if you throw in the metric offshoots.
    PTC is falling behind a little on covering these standards with provided tables, though.
    The easy way is to create the hole and a cosmetic thread. It all depends on how you manage the annotation for the hole.
    Mar 11, 2015 1:53 PM UTC
    I created one years ago. Hole file names can only be 3 charactrs long!!!
    I have attached the file, but take no responsibilty if the data is not correct for your use.
    Mar 14, 2015 5:59 AM UTC
    Ben, have a look at the reply in my idea submission...
    and if you can't see the ideas... this is the quote from Paul:
    But I'm not sure what is meant by this 3 character limit... I have recently made table named ISO-COARSE.HOL, and it works fine.
    Mar 16, 2015 2:47 PM UTC
    In older versions of WIldfire, 2 & 3, a .hol could only be named with a 3-charcater name; iso.hol, unc.hol, etc. It appears that Creo has lifted that limit.
