Jun 26, 2012 4:42 PM UTC
How to display the Machanica Mesh
One of the users is using mechanica and wants to know how to display a mesh
he just created. Can someone point to me to the setting. I recall a mode
where one can see surfaces is Blue, edges in black and nodes in yellow to
review the mesh.
regards,
Alfonso
    Jun 27, 2012 7:09 AM UTC
    > a
    > mesh he just created. Can someone point to me to the setting. I
    > recall
    > a mode where one can see surfaces is Blue, edges in black and nodes
    > in
    > yellow to review the mesh.
    > regards,
    > Alfonso
    What version of Pro/E are we talking about here?
    Do you want to see the mesh in the Pro/E model or in the result
    windows?
    For WF4:
    In the result windows you can do
    Edit; Result Window; Display Options; Show Element Edges
    In the Pro/E model you can do
    AutoGEM; Create; File; Copy Mesh from Study
    and you can tweak the settings using
    View; Simulation Display; Mesh
    Alternatively, for the hardcore users, you can switch to Pro/M
    standalone, if you have that, but that method is deprecated 😉
    Best regards,
    Patrick Asselman
    Jun 27, 2012 7:43 AM UTC
    Hi Alfonso,
    As far as I know, you can generate (or retrieve) the mesh using the
    'mesh' toolbutton whilst editing the Mechanica model; or you can select
    Show Element Edges in the Result Window Definition dialogue box.
    There may be other options in Independent Mode, but I only use
    Integrated Mode.
    HTH,
    Jonathan
