Oct 22, 2015 12:24 PM UTC
How to fix an invalidated key frame sequence in Creo Parametric animation?
I created several snapshots to make an animation with in Creo Parametric.  I created the key frame sequence, but when I try to play the animation I keep getting the following error "Key frame sequence Kfs1 invalidated and will be ignored."  What does this mean?  How did I get an invalidated key frame sequence and how can I correct it?  Has anyone had this problem before?  I am not sure where to start because I did the process exactly as I have before, and it worked previously.
    lrafter1-VisitorAuthor
    Oct 23, 2015 11:52 AM UTC
    Setting all the bodies to desired resolved the issue.  Don't know why the bodies can't be unspecified or required on this animation though.
    2-Explorer
    Nov 13, 2015 11:05 AM UTC
    duplicate thread - see How to fix an invalidated key frame sequence in Creo Parametric animation? under main community PTC Creo
    (anyway, thanks for adding the answer)
