Oct 21, 2015 8:30 PM UTC
How to fix an invalidated key frame sequence in Creo Parametric animation?
I created several snapshots to make an animation with in Creo Parametric.  I created the key frame sequence, but when I try to play the animation I keep getting the following error "Key frame sequence Kfs1 invalidated and will be ignored."  What does this mean?  How did I get an invalidated key frame sequence and how can I correct it?  Has anyone had this problem before?  I am not sure where to start because I did the process exactly as I have before, and it worked previously.
lrafter1-VisitorAuthor
Oct 23, 2015 11:52 AM UTC
Setting all the bodies to desired resolved the issue.  Don't know why the bodies can't be unspecified or required on this animation though.
2-Explorer
Nov 13, 2015 11:06 AM UTC
duplicate thread - see How to fix an invalidated key frame sequence in Creo Parametric animation? also under main community PTC Creo
(anyway, thanks for adding the answer)
