Oct 22, 2015 12:21 PM UTC
How to fix an invalidated key frame sequence in Creo Parametric animation?
I created several snapshots to make an animation with in Creo Parametric.  I created the key frame sequence, but when I try to play the animation I keep getting the following error "Key frame sequence Kfs1 invalidated and will be ignored."  What does this mean?  How did I get an invalidated key frame sequence and how can I correct it?  Has anyone had this problem before?  I am not sure where to start because I did the process exactly as I have before, and it worked previously.
    lrafterAnswer
    Oct 23, 2015 11:51 AM UTC
    Setting all the bodies to desired resolved the issue.  Don't know why the bodies can't be unspecified or required on this animation though.
    BenPerry
    Oct 22, 2015 12:27 PM UTC
    Ryan Kelley‌, please move to PTC Creo‌ or thereabouts.
    Oct 22, 2015 1:41 PM UTC
    I've moved this discussion into our PTC Creo‌ product community as Ben Perry‌ suggested.
    lrafter1-VisitorAuthorAnswer
