Sep 9, 2014 7:40 AM UTC
How to load a model from Windchill in Creo via vba api
I have a list in Excel with model numbers to load in Creo via the vba api. The models reside in Windchill. How can I do this ?
I tryed next but this does not work:
Dim model As IpfcModel
Set model = gSession.GetModel("48603102.PRT", EpfcModelType.EpfcMDL_PART)
If Not model Is Nothing Then model.Display
Any help is appreciated.
Bernard
    Sep 9, 2014 8:12 AM UTC
    Found it after looking into Excel attachments :
    'Create a modeldescriptor to the Pro/E Model
    Dim oModelDescriptorCreate As New CCpfcModelDescriptor
    Dim oModelDescriptor As IpfcModelDescriptor
    Set oModelDescriptor = oModelDescriptorCreate.Create(EpfcMDL_PART, sNumber, Null)
    'Retrieve the model into the oModel handle
    Set model = gSession.RetrieveModel(oModelDescriptor)
    'Create a new window which displays the Pro/E Model
    Dim oWindow As pfcls.IpfcWindow
    Set oWindow = gSession.OpenFile(oModelDescriptor)
    'Activate the new window
    oWindow.Activate
