how to merge several surfaces one-time with the proe
how to merge several surfaces one-time with the proe.i know ug can easily apply this command.when will the PTC company can solve this question.
    Not sure what version you are using but you can do this starting in WF4. Not sure about WF5.
    Jim_zhao1-VisitorAuthor
    Make sure the surfaces are trimmed to the boundaries where the surfaces will attach. You should then be able to select two surfaces, select the merge feature, and add additional surfaces by holding the CTRL key and selecting additional surfaces. You could also select all the surfaces you want to merge then select the merge feature.
