Aug 13, 2015 6:11 AM UTC
how to set units in creo permanently
anybody tell me to set units
    Aug 17, 2015 9:23 AM UTC
    Hi Kishore,
    What do you mean with units?
    - Units on parameters, you need to declare them at creation in C TK. Unitssytem of files ?
    - You need to change them on every part / assembly and on your Start Objects (parts, assemblys) to get it permanent same. You can do it manual, by mapkey, or by an external Tool like Model Process (http://mp.inneo.com, free for single parts after registration) or SmartUpdate (B&W Software GmbH, I think you can get also test license, ...).
    Br,
    Eike
    Aug 17, 2015 9:25 AM UTC
    Oh ... or you can program it by urself and build it as a triggered solution in (C, C++, Java, JavaScript, VBS) whatever you like (C, C++, have an xtra license).
    Br,
    Eike
    2-Explorer
    Aug 21, 2015 4:29 PM UTC
    Or are you simply asking how to set the default units when working with Creo? (e.g. config.pro option pro_unit_sys)
    Aug 24, 2015 12:23 PM UTC
    you can change the units from model properties by going to FIle->Prepare->ModelProperties.
    Aug 26, 2015 12:47 PM UTC
    From the above mentioned path, select the Detail Options link and it opens a window for you to be able to change parameters as you see fit. You can even save your changes to an external file and then import it later on as needed. Altho I think that the changes you make in the Detail Options page is only applied to the active drawing.
    Sep 19, 2015 6:44 AM UTC
    Hi
    If you are talking about setting the units through toolkit each time you open your session you can use ProMdlPrincipalunitsystemSet() and call it in your initialize module.
    manually you can change the same in ModelProperties under Prepare.
