Aug 10, 2015 10:39 AM UTC
how to start framework in creo 2.0?
please tell me how to start advance framework in ptc creo 2.0/
    Aug 10, 2015 1:49 PM UTC
    You need to set option afx_enabled to yes in your config.pro and restart Creo. After restarting you should be able to access Framework tab from the assembly level.
    Aug 11, 2015 8:36 AM UTC
    also Advanced Framework Extension option must be checked during installation.
    Look, whether Creo2_LOADPOINT\Creo 2.0\Common Files\Mxxx directory contains efx subdirectory.
    Martin Hanak
    Oct 25, 2016 2:58 PM UTC
    hi ! what to do if i dint install the first time? ..other than reinstalling again....tnk u
    Oct 25, 2016 5:40 PM UTC
    from my point of view reinstallation is the only reliable procedure .
    MH
    Mahesh_Sharma
    22-Sapphire I
    Aug 13, 2015 4:05 PM UTC
    Uttam,
    Advance framework is available in assembly mode. Create an assembly to check tab for Advanced Framework
    Mahesh_Sharma
    22-Sapphire I
    Sep 4, 2015 4:17 PM UTC
    Uttam,
    Did you manage to work with AFX?
