Aug 14, 2008 7:29 AM UTC
How to swap colume on 2D repeatregion?
Dose anyone know How to swap or rearrange the PARAMETER Column on the 2D repeatregion? Appreciate, Peerapong
    Aug 28, 2008 2:06 PM UTC
    open the family table, select the first column, then CTRL+select the second one, now both are selected, go to edit, swap the column.....
    Oct 7, 2011 2:09 PM UTC
    I am having the same problem. I would like to re-order columns in a drawing 2D table, created from a family table in the model. Any ideas?
    Oct 7, 2011 5:44 PM UTC
    Hi Dwight
    I would suggest he same as replied in the earlier post
    Go to the family table of the part
    swap the columns as per your requirement;
    This will automatically reorder your columns accordingly in the drawing
    Regards
    K.Mahanta
