Jan 29, 2015 6:52 AM UTC
How to update all sheets automatically?
Dear All,
How to update all the sheets ,please mention?
and after updating how to make dxf of all ,any suggestions?
Thanks ,
Manish
    Jan 29, 2015 9:42 PM UTC
    To update all sheets try this mapkey:
    mapkey us ~ Command `ProCmdDwgSelectAllSheets` ;~ Command `ProCmdDwgUpdateSheets`;
    It selects all sheets and updates.
    To export all sheets, under the Export environment for DXF select Tab "Sheets" and option "all sheets as paperspace".
    Jose
    Jan 29, 2015 7:15 AM UTC
    Please clarify what you are updating.
    Normally all parts and assemblies in memory update in real-time.
    Sometimes the models in drawings require regeneration. That is not sheet dependent.
    mgupta-41-VisitorAuthor
    Jan 29, 2015 7:19 AM UTC
    Actually after making the drawing from some assembly whenever I changed something in assembly or in part ,in the drawing file it will not automatically update i have to update it by "Update Sheets " symbol.
    and next thing i have around 18-25 sheets in one .drw file and i have to convert it to dxf for some internal reasons.
    so for this i have to seperately make dxf file of each sheet.
    Hope you understand .
    Any clarification please tell.
    Manish
    Jan 29, 2015 8:42 AM UTC
    StephenW
    Jan 29, 2015 12:36 PM UTC
    The way I update all sheets is to use shift+select sheet 1 thru sheet x. The I go to the review tab and select UPDATE SHEETS. If all sheets are selected, all sheets will be updated.
    This is by no means automatic but with a drawing with that many sheets, you probably don't really want automatic view regeneration anyway.
    We also have a config.pro option set disable automatic view regeneration: auto_regen_views NO . We set this due to large assemblies taking a long time to update on drawings.
    I would create DXF files of multisheet drawings using a mapkey if I had to do it a lot. It is also not automatic, but it is much faster than individually making the selections per sheet.
    Jan 29, 2015 2:50 PM UTC
    is there an option save_display yes/no in your config.pro ?
    If a drawing is saved under this option
    - yes means the drawing will be opened as saved. You have to update your drawing, regenerating wont help.
    - no means drawing will be regenerated on opening.
    Reinhard
    Jose
    Jan 30, 2015 5:24 AM UTC
    Any map key can i generate that all the sheets in model space ...
    Jan 30, 2015 11:30 PM UTC
    Just using mapkeys, I don't see how to do it.
    My best suggestion is to build a big mapkey that activates sheet one and export to dxf, activates sheet two and repeat....
    Attached is a mapkey that does this for 15 sheets, you can add more just copy/pasting the lines and changing the numbers.
    I think this will solve your problem
    Jose
    Jan 29, 2015 10:00 PM UTC
    Try attached mapkey for update and export.
