Sep 23, 2015 2:18 AM UTC
i downloaded free version of student
i downloaded free version of student but i am unable to use it. when i open creo parametric it saying invalid code and name.
what ii have to do and why i am getting this..
    Sep 23, 2015 1:51 PM UTC
    Sep 24, 2015 3:51 AM UTC
    It is better to buy a commercial version
    Sep 24, 2015 2:27 PM UTC
    The software is technically the same.
    PTC does modify all printouts with a watermark saying it was created on an educational version.
    You cannot use the educational version for commercial work.
    The files cannot be opened in the commercial version.
    Commercial version files cannot be opened in the educational version.
    Sep 26, 2015 5:27 PM UTC
    Ram,
    You have a license problem. The system recognize your software as the commercial version and is trying to retrieve the name and code for that. What you have to do is change your license type.
    To do this, post the same question or send an email (better the email) to the Creo Academic Support.  Then, they will send you a file that you can use if you "reinstall" the software, that file in fact, is the Student License. Let me know if you solved the problem.
