Sep 15, 2015 12:13 PM UTC
idx
Any ideas about generating IDX files from Element direct?
    Sep 15, 2015 5:50 PM UTC
    No, because I do not know what .idx has to do  with a 3d cad
    Google:
    The file extension .idx usually denotes an index. Such is created by various programs and uses. Do you want to open an IDX file, you must use for each matching application.
    Most references an IDX file to a database, because the index is intended to speed up the search in a database. You can open a file IDX usually only when you access the program that the IDX file created.
    Which program should open your .idx file?
    Sep 16, 2015 1:43 PM UTC
    FriedhelmK,
    You haven't needed to import PCB's (Printed Circuit Boards) have you?
    IDF, IDX
    Mike
    MarcoTosin
    Sep 16, 2015 2:55 PM UTC
    Take a look at this discussion ECAD-MCAD collaboration
    Marco
    MarcoTosin
    Sep 16, 2015 3:01 PM UTC
    This is a thesis on ECAD-MCAD collaboration https://www.theseus.fi/bitstream/handle/10024/72206/Valkky_Markus.pdf?sequence=1
    It talks also about IDX format
    Marco
