Apr 25, 2013 4:27 PM UTC
IF Diameter
Is it possible to add a temp relation that says IF a diameter = 5.18,
then make it = 5.00? Gotta lotta holes to change and thought maybe I
could change them in one fell swoop.
    TomU
    Apr 25, 2013 4:51 PM UTC
    Are these all in one model, or many models?
    Exact syntax for one diameter is this (replace DIAMETER with the dimension name):
    IF DIAMETER == 5.18
    DIAMETER = 5.00
    ENDIF
    Tom U.
    wfalco16-PearlAuthor
    Apr 25, 2013 5:06 PM UTC
    Sounds good.
    I tried and get this...
    IF DIAMETER == 5.18
    errorInvalid symbol 'DIAMETER' found.
    DIAMETER = 5.00
    ENDIF
    Apr 25, 2013 6:00 PM UTC
    Replace DIAMETER with the parameter that is originally driving the diameter dimension.
    IF p254 == 5.18
    P254=5.00
    Endif
    If all of the holes are in a pattern then this should work, but 1 edit to the master hole will do the same thing.
    If your holes are defined independently, then nothing will work, unless you have changed them to use a defined parameter for the diameter.
    Thank you,
    Ben H. Loosli
    USEC, INC.
    Apr 25, 2013 6:05 PM UTC
    You could try using Edit Program, which opens in a text editor, and replace 5.18 with 5.00. If there are no dimensions at 5.18 that you want to preserve, just to a mass replace.
    In Creo2 it's:
    Tools > Model Intent > Program > Edit Design
    (Warning, if it's an assembly, you'll need Advanced Assembly to use this.)
    In Reply to Wayne Falco:
