Feb 10, 2016 8:50 PM UTC
Iges to Models in Creo
Long time Unigraphics/NX user here and new to Creo 2.0.    I need to create several models that are basically revolved.   I will import in some Iges files with a cross section.   In Creo, I take the lines in the cross section and project them into a sketch and then I revolve the sketch to create a solid.    Is there an easy way to assign dimensions and break the link to the imported files and be left with what looks like a "clean" Creo file with a sketch, etc.? Thanks
    Feb 10, 2016 10:23 PM UTC
    Mark,
    -After you have Projected your cross-section,  you can open the "References" box and delete all the references. (Creo will automatically assign "soft" (grey) dimensions to your section)
    -Select new Vertical and Horizontal references.
    -Create "hard" (yellow) dimensions per the scheme of your choice.
    -Done.
    Good Luck
    Bernie
    Bernie Gruman
    Owner / Designer / Builder
    www.GrumanCreations.com
    Feb 11, 2016 9:15 PM UTC
    Below is a view of the section I'm revolving.  The iges file only contained some lines which represented a section.  I'm not sure where the "References" box is.  Only thing I could find is if I right click the sketch and I get the option, "Edit References".  I don't see any option to just delete the references.
