Aug 29, 2012 9:54 AM UTC
Import relations file
Hello all,
We can import relations into our models using a text file but if there are already some previous relations in the model they get erased when importing the file. Is there any way of preserving the already existing relations when importing new ones?
A. Baridó
    Aug 29, 2012 10:40 AM UTC
    Hi Antonio...
    Two options come to mind. first, consider adding your new relations as "Post Regeneration" (or moving your old ones if appropriate). Post regeneration relations are good for things like mass properties calculations because they are evaluated after the model has been regenerated. However, if your relations are controlling dimensions, you'll probably want to keep them set to Initial so the values are evaluated before the model is actually regenerated.
    If Post Regeneration isn't an option, plan "B" would be to make a mapkey that first exports your existing relations as a text file, merges them with the new relations, and then imports the merged list. You can concatenate or merge two text files in several ways. Perl is my favorite text file processing utility... but you can easily do this with a Windows batch script, too.
    To bring it all together, you'll probably want to write a series of mapkeys. I'd have one mapkey to export your relations. Then, I'd have another mapkey setup to run the small batch script or perl script to merge the files. Next, I'd create one mapkey would read back in the merged file. Finally, I'd create one last mapkey which runs the other 3 mapkeys in sequence. This gives you ONE key to do the entire operation.
    If you need further advice, a sample batch script to merge the files, or even a full demonstration, let me know. I love helping people with issues like this- but I'm getting absolutely buried at work these days. It's been tough for me to write back quickly. Still, if you get stuck, I'll try to carve out some time to step you through the process.
    Thanks!
    -Brian
    Hi Antonio...
    Thanks!
    -Brian
    Bari14-AlexandriteAuthor
    Aug 29, 2012 10:48 AM UTC
    Thanks Brian for your valuable description and effort to conciliate your job and helping the community.
    A. Baridó
    Aug 29, 2012 12:20 PM UTC
    Thanks Antonio...
    When I can't do everything all at the same time, I feel like I'm letting people down. This is why I try never to sleep!
