Oct 31, 2008 2:49 PM UTC
Importing points from excel spread sheet
How do you import points from an Excel spreadsheet into Pro/E?
    Oct 31, 2008 3:26 PM UTC
    Michael, You need to save the excel file as Text (tab delimited).This will save a txt file.You need to rename this to a *.pts extension. This pts file can be imported in Pro/E.Exact steps are given in help. Also the excel file should just contain the point co-ordinates..You need to remove everything else. Hope this helps, Rameet
    Aug 6, 2013 9:47 AM UTC
    Hi Rameet,
    I followed exactly the same procedure what you have mentioned in this post.
    But the *.pts file is not highlighting when I am trying to import the file.
    Please suggest with a detailed procedure to import the points through excel file.
    Thanks in advance.
    Aug 30, 2013 9:55 PM UTC
