Oct 20, 2014 6:57 PM UTC
Improve measuring command
Is there somewhere to post enhancement requests to Creo? The Measure command is really frustrating to use. Anyone familiar with using SolidWorks measure command where you can show dual units, not have to Cntl+click, not have the measurement show up behind the toolbar, not switch between measurement types? Also, SW has someplace for service requests, enhancement requests, etc. Does Creo have this? Obviously, it'd be naive to just say make everything like SW, but I really wish Creo would take a cue from SW on this front.
    Oct 20, 2014 7:44 PM UTC
    There is an Ideas section in the forum if you have active maintenance.
    This has been lamented for quite some time and there seems to be very little traction on the development end.
    The UI in Creo still lacks a lot to be desired. Not just measurements.
    If you have access to the Ideas section, feel free to search "measurement" and vote for those that interest you.
    Jan 23, 2015 1:10 PM UTC
    Found the link for ideas and thought I'd share it! http://communities.ptc.com/ideas/
    Since the form isn't very straightforward, here are some okay instructions on how to use it:
    http://communities.ptc.com/docs/DOC-2523
