Inertia Relief in Wildfire 3
Has anyone seen a beta of the Inertia relief solution in WF 3?
Will inertia relief apply the appropriate accelerations at the center of mass in order to balance the applied loads?
If so, will these accelerations vary as the center of mass (and inertia properties) vary? That is, will an optimization study be able to use inertia relief analyses?
Thanks.
Joe
