Jun 19, 2012 11:38 AM UTC
Insert Advanced Pipe in Creo ?????
In Pro/E wildfire there was Insert : Advanced : Pipe.
Does anyone know where this is in CREO?
Brian
    Jun 19, 2012 1:21 PM UTC
    Are you talking about creo1 or creo2? In 2 you can find it via the search (top right corner) which also tells you that it is not part of the ribbon interface...
    Jun 19, 2012 1:26 PM UTC
    I am working in CREO 1 ! I tried typing it in the search box, but I didn't come up with anything.
    Jun 19, 2012 2:22 PM UTC
    Hm, sorry, I do not have creo1 anymore to check it...
    Jun 19, 2012 2:46 PM UTC
    With a part file open, I went to the CUSTOMIZE QUICK ACCESS TOOLBAR and then looked under ALL COMMANDS, it is in there under PIPE. I added it to my quick access toolbar and I am sure you could add it to other toolbars as well.
    Hope this helps
